25th February 2013, 21:19
Ah I see
25th February 2013, 21:21
Originally Posted by chargerstang
I have a question about the inner boot extender. Has only the lower part will be reduced by 2.5 " ?
Great start
Cut down both sides here ..V...and along to bottom of the boot extender and overlap the two parts as shown and bond together with Tiger Seal.
Also trim the edge that fits against the original rear panel of the car to clear bumper brackets etc. You will need to cut holes as shown to access cables for rear lights.
25th February 2013, 21:25
Hi Chris,
thanks again
I give a update tomorrow.
Greets Henry
26th February 2013, 20:28
Day #2
Everything went according to plan.
2x electrics relocated
The rear body kit attached with 2K adhesive
Hinges attached
Petrol cap sized and drilled.
Not much but it`s twice.
Greets Henry
27th February 2013, 19:23
Day 3 of the rebuild.
2 Times Relocation of the fuse boxes and the expansion tank
I wanted to put the fuse box "only" inside.
That we did not like, then we cut through all the cables and 12 "extended.
Now it fits perfectly. There are about 30 wires per car and takes 2 hours.
Cut pieces to put in between, solder, insulate and re-wrap.
Tomorrow there is a new update.
regards
Henry
27th February 2013, 19:43
Left hand drive You have ABS unit in the way, good solution moving fusebox
27th February 2013, 19:51
Hi Chris,
yes it's just everything on the "other" side.
Now at the site, I like it also the best.
Tomorrow we start with the front end.
Love it, thanks again for the MX250 kit.
Greetings from Germany
Henry
1st March 2013, 20:11
Two more images
Tomorrow we will install the lights and mount the hinges (front) of the morris minor
And then we will begin with filling and sanding. How long you need for this “because normally”
2nd March 2013, 20:56
Making rapid progress Henry. Bang on target with your wiper spindle holes too!
As too how long sanding should take......you can take as long as you like! Its the bit I enjoy the most.
2nd March 2013, 21:06
HI NicK,
yes it goes ahead.
the bit I put over it for the exact angle.
We want to cut out the back window on Sunday.
How wide must be the edge (all around) of the rear window?
I do not want to cut too much
2nd March 2013, 21:11
I laid the glass in position, measured the rubber thickness, which I think, was about 4mm, and added that 4mm all around the glass edge.
2nd March 2013, 21:13
Thats what we need,
1000 Thanks
I have to rebuild the engine hood. because the minor hinges do not fit
Has anyone installed the 10 "long?
Greets Henry
2nd March 2013, 22:49
Do check your window rubber before cutting. Its +4mm from memory, but I may be wrong!
3rd March 2013, 09:56
Hi Heinrich
As Nick says, lay just the glass on the flange and draw around it then mark 4-5mm INSIDE the line, so that the hole is SMALLER than the glass.
3rd March 2013, 12:16
Hi Chris, hi Nick,
thanks for the details.
More Images on Monday
and my daily question
has anyone ever installed fog lights in the 2 round holes.
Perhaps the mini one fog lamps will fit?
http://commons.wikimedia.org/wiki/Fi...lift_front.JPG
Greets Henry
3rd March 2013, 21:06
Great idea about the lights, would look cool
4th March 2013, 19:41
Hi Chris,
we will try to install the mini Foglamps.
Today, I have rebuilt the cutout for the side window.
A thick rubber gasket I did not want
There was a gap of ~ 30mm between body and window.
Now, the difference was reduced to 2-3mm.
Finally, I start filling.
Now it looks like a car.
4th March 2013, 22:26
Hi Chris,
Great progress mate! Please explain what you had to do on the window gaps
5th March 2013, 19:48
Hi it was easy,
to reduce the gap, I'm just drawn a line outside to the window.
I Cut it Right there.
The sawed-off part of the back and put it fixed.
To get around 3mm space between the window and roof I put on bonding spacers between.
Until the glue was dry I had screwed 2 screws for fixing. Thats it
Sorry for my bad english, I hope you can do something with the instructions.
regards
And my daily update.
5th March 2013, 20:34
Heinrich, how long do you have left? You are nearly done! Are both cars at the same stage?
