24th September 2023, 14:11
The programme reads: No.78 Richard Wilson Maserati 250S 2490cc 1957 Red. If you went for the Tribute, what underpinnings would you go for?
A bit of googling and it does appear to be an original !
As for a base car the Maserati has a narrow track and short wheelbase so it lends itself towards a "7" style chassis. Some of engines they used were 4 cylinder twin cams like the Fiat / Lancia / Lotus designs with twin side draught carbs. So a replica under bonnet area could be created too !
1st October 2023, 09:31
Matching Switches - ish.
A few days ago, when weather permitted, I swapped the tacky plastic switch for the 'Repro Lucas' item I'd bought on Ebay. It has a galvanised looking finish, unlike the chrome original, and the mechanism behind is encased in a soft plastic shell rather than the hard black plastic of the Lucas item. Only time will reveal if it will A) tarnish and/or B) fail early. I'll keep looking for an original on Ebay.
It's the one to the right of the indicator gubbins.
Having fitted the electric fan, I began wondering about the thermostat as I couldn't recall having fitted a new one - a trawl through this blog proving fruitless. There was one fitted, which I removed for testing - it was a dud, refusing to open in a pan of boiling water. Not a lot of good. I ordered a new one c/w gasket and cleaned the mating surfaces of its housing and the top of the water pump. Once it arrived I fitted it, fired her up, and watched in dismay the resulting mini Niagara . I think the problem was the tissue thin gasket. Anyway, I've ordered a couple of new ones and some likely looking gasket goo, having not found a supplier of my reliable six decade standby, Red Hermatite. If all goes well I shall take her to Prescott next Saturday.
Regards, Mick
4th October 2023, 08:45
Yes that's real, I was there at castle combe too and spoke to him briefly, I've also photographed that car at silverstone classic too
4th October 2023, 09:12
Underpinnings? Got to be a GT6 or Vitess 6 anything less would be sacrilege,no?
4th October 2023, 18:52
Some of the OSCA cars by the Maserati brothers used a Fiat based twincam engine ! The MT4 being a good example. But yes, a straight six would suit it well !
5th October 2023, 10:28
After posting the above last Sunday, I decided that the very distressed volt meter was rather spoiling the overall effect, so I hit Ebay searching for used same. After ploughing through the plethora of mis-advertised ammeters I found a nicely presented Tudor branded one BIN at a reasonable price which was delivered, very well packed, yesterday.
Not having been successful two days running in using the instant gasket installing the new thermostat - ham-fisted, moi? I set to releasing the LH end of the dash, wedging it open with a block of wood to marginally improve the meagre access, having first disconnected the battery's earth. Despite removing the recently installed switch just above it, I couldn't get enough purchase on the gnurled nut holding it on. OK, remove the fuel gauge immediately below for a try that way. Having done that, which was a struggle in itself, I was just about able to access the nut with long nosed pliers - a squirt of WD40 and lots of cursing and it was off. Having put its replacement in I remembered that a nicer fuel gauge had come with the Phaeton so I dug that out of my box of clocks and substituted it. Reinstating the dash and re-connecting the battery I was delighted, if not amazed, that they both worked a treat. A hat trick of successes was achieved as I'd spotted a dodgy connection in one of the tacho. wires and remade it so said clock now works consistently . No picture as yet.
Today it's back to the thermostat housing problem. Third time lucky? Maybe.
Regards, Mick
Reason: Spelling.
5th October 2023, 15:08
D'Oh!
This afternoon I had another crack at fitting the thermostat housing. Once it was off I began removing all the instant gasket which was stuck like the proverbial to a blanket, first from the housing, then the top of the water pump. It's held in place by two screws, one of which is much longer than the other. I noticed that there was water from yesterday in the longer tapped hole so stuck a screwdriver in to clear the mystery blockage. Not possible, as the sheared remains of the 55 year old screw were stuck halfway down the tapping. I ground a little off the end of the broken screw and fitted it with a plain washer so that it wouldn't bottom in its hole: I think this was probably the fly in the ointment. I also ran a die down it and its oppo as they were fairly rusty. I again cleaned both the mating surfaces with acetone before applying the instant gasket, waited the recommended ten minutes for it to skin over, and reassembled. According to the blurb it takes 24 hours to fully cure, so I won't top up the rad and fire her up until tomorrow. Fingers crossed.
Here's the dash with its replacement clocks, looking much better IMO.
Regards, Mick
7th October 2023, 17:42
3rd time lucky.
Yesterday I uncovered the beast and, in true pessimist fashion, topped up the rad. and fired her up. Bingo, not the tiniest trace of leakage. However, there was vapour floating up from the exhaust manifold. I first assumed this was carelessly spilled water soaked into the exhaust wrap and boiling off. No! A quick sniff indicated oil. Aaaaaaaaagh! So, out with the home made ramps kindly donated by my Polish ex-neighbour when he quit the UK.
Worming underneath with a wander light revealed damning evidence of a leak, but from where? I first checked the sump bolts and got a hit: they all needed at least a quarter turn, so I'm guessing that the gasket had shrunk over the years (decades?) of inactivity. Rolling back to earth and the smoke had vanished. Result!
Today's imagined sortie in her failed to materialise as my daughter had inadvertently boxed me in, her mind being elsewhere yesterday, and I didn't want to harass her at stupid o'clock. So, off to Prescott in the tin top. I'd not got far when I fell in behind this top-down Mk1 Sprite which I followed all the way to the venue, the pilot turning out to be a competitor.
There was the usual fabulous assortment in the paddock, which included, to my eye, some real gems. Chief amongst them was this glorious Allard J2 powered by a 3917cc flathead V8 with an overhead inlet valve conversion.
Next was this 1920 Bugatti with a novel front track modification.
Last but by no means least was this 1380cc A series powered A40.
All in all a brilliant day out to round off this year's accessible speed hill climb season. Roll on 2024!
Regards, Mick
Reason: Typo.
11th October 2023, 14:11
Tonneau Tidying
Having worked out, at long last, a workable partial solution to my Phaeton's imagined engine mountings, I ordered some box section ally which I hoped would arrive today. No such luck! So, I turned my attention to trimming the Monaco's tonneau cover. I'd originally intended to edge it with the special tape in black but a trial run with an off-cut of the double duck, also black, with black thread had my eyes popping out, despite brightly illuminating the work area with the Anglepoise lamp. Thinking back to the A352's tonneau, I decided on body colour matching trim. The trim has to be folded over the edge of the fabric and held in position whilst sewing, tricky to say the least, so I decided to iron it folded first. My second hand sewing machine had always been a bit jerky, despite my having given it a good clean and lube overhaul on purchase. I realised this morning that I'd not done the same with the accelerator pedal. Opening it up revealed ancient fluff and light corrosion on the rheostat, the latter responding well to contact cleaner. A spot of oil on the hinge and its operation (tested power off) was way smoother. Result!
I then remembered that I'd fitted the 'lift the dot' gubbins after my now departed Stateside seamstress friend had edged my A352 tonneau for me. The fasteners would need to be removed from three sides of each half to be double sure that needle breakage was avoided. However, the long centre edges of each half had sufficient overlap meat for me to make a start on one edge.
Taking it very steady with the now super smooth machine saw me completing my first attempt with reasonably tidy success. Once the metal fasteners are off (there are 28, each with four tabs to be bent up!) I can both do the rest of the edge and work out how to make tidy corner joins.
Regards, Mick
20th October 2023, 13:27
Excellent work. Looking forward to seeing the finished cover.
I now see who to turn to when it comes time to make my leather seat covers
28th October 2023, 08:27
Many thanks for encouraging comment Kon .
Sadly, my domestic sewing machine couldn't cope with leather and, as a committed vegan, neither could I. Faux leather vinyl, however...
Regards, Mick
5th November 2023, 12:29
They're never really finished...
I remembered this morning that my poncey custom reg. no. has been languishing on its DVLA retention certificate for three years now, since its removal from the A352 'D-Type'. As the Phaeton I'm building is on a Q plate, and the no. would simply look wrong on my Jazz, I decided its last resting place should be on the Monaco .
Reading the blurb on the V778 which details the hoops which require jumping through, I also remembered that I hadn't affixed the Spitfire donor's chassis plate to the Monaco. Digging it out and offering it up to likely locations, I plumped for the scuttle brace as favourite.
The handbrake lever made aligning the drill for the LH rivet hole tricky, which has resulted in the plate being slightly off level. I persuaded myself that this simply adds to the overall quirkiness
So, tomorrow I can get the necessary paperwork together and make my application to DVLA. I already have pressed ally black and silver plates which I purchased in the 80s for the imagined Moss Midge which never was. The reg. no. was originally on a 1950s Minor 1000 in Lincolnshire. I found it advertised in The Sunday Times in '72, it cost 35 quid, a fortnights take home pay then. Bizzarely, MDO 1 was for sale in the same ad. for a mere 400. Dream on! Vanity doesn't come cheap!
The 'D' is for Desmond. I'm thankful that my father's wish that it should be my first name was vetoed by SWMBO!
Regards, Mick
11th November 2023, 09:06
A testing time...
Earlier in the week, whilst hitting the DVLA website to make my 'Cherished Number' transfer application, I learned that, despite the Monaco being MOT (and tax) exempt, a current test is a prerequisite. I know I've been a little cavalier to have not bothered so far, but will nevertheless find out soon if my faith in my building ability has been misplaced. I'll keep an eye on weather forecasts to ensure a dry day for booking. I'll go to the place which sympathetically tested the A352, as they let me sit in my cramped creations whilst they poke it about on the hydraulic ramp.
Regards, Mick
p.s. I know a second pair of eyes etc. blah blah so please don't preach to the (partially) converted...
14th November 2023, 08:31
I would have assumed that you'd get an MOT anyway, after all this work, as an easy way to prove that it's now road-worthy again, (for insurance at least). I think i'd want to get one anyway, like you say, for a 2nd pair of eyes.
I watched a kit-car helper video the other day which said you should get an MOT before taking a car for IVA, which was news to me. I thought that was the whole point of the IVA, but apparently the MOT man actually creates the new entry in the system for it, not the IVA man.
I cant wait to see this thing in the flesh... do you already know which car shows you'll be taking it to next year?
14th November 2023, 15:30
Hi Kon
First of all, many thanks for your interest. Seeing more than 170,000 hits on this blog is gratifying, but there's nothing like the personal touch .
Whereabouts in the country are you? My regular events are Shelsley Walsh; Prescott; Castle Combe; Gloucester Goes Retro; and possibly the Kit Car Show, although if this year's is anything to go by, it's withering on the vine. There's also a small meeting on the morning of the third Sunday of the month at Cheltenham's Staverton Airport attended by sundry petrol heads. Every year, on purchase of the next's calendar, I hit all the venues' web sites and ink in their dates. I also sometimes fork out for a copy of Classic Car newspaper which has a decent section regarding the subsequent few weeks' events. Fingers crossed for decent weather in '04!
Regards, Mick
Currently Active Users Viewing This Thread: 346 (0 members and 346 guests)
