Old 18th August 2006, 15:09
limpabit's Avatar
limpabit limpabit is offline
Cheers Grant. That's Great.
Don't think it's worth it making a torrent as there's only a few here.
Old 18th August 2006, 18:35
craig's Avatar
craig craig is offline
I need help with installing this if anyone can as when trying to install it will not give me a directory for location and the ones that are available are current programs! Only succeded in crashing system a few times so far
Old 18th August 2006, 19:38
limpabit's Avatar
Downloading now.
Will give step by step instructions when ready. Won't be long.
Old 18th August 2006, 20:44
limpabit's Avatar
Grant. Thanks very much for the download.
Here's how I did it guys.
First download & install Winrar from
http://www.download-zone-free.com/winrar/
create a directory on the C: drive called epc so c:\epc
Click on Grants link. When asked select save to and select c:\epc.
Open epcaug2006.rar in c:\epc. Just double click it and it should open in Winrar.
Click extract to button then select ok button. This should start extracting the files.
Now open your CD burning program like Nero. In Nero, you select File, Open Image file. Point it to C:\epc\epcaug2006\epcaug2006.ISO once it's been extracted.
Then Burn to CD.
If the setup don't run when you insert the Cd, run setup.exe on the CD.
Select ok or next all the way through till the end.
Any problems let me know.
Old 18th August 2006, 23:02
craig's Avatar
I have downloaded it again to c:\epc and extracted files and each time I try to run or install, it gets so far and then asks for directory to install to??
My last epc already had the directory there
Old 19th August 2006, 07:47
limpabit's Avatar
hmm My setup was the same. I had an older version installed as well and worked ok.
I'm assuming you have admin access when you log on to XP. I would uninstall older version (Start\All Programs\MGRover\uninstaller). Then try to install newer version.
Have you got MSN Messenger? If not download (http://get.live.com/messenger/overview)it and set up. Then at a good time, I can connect to your machine and see what's going on.
Old 19th August 2006, 09:04
alackofspeed's Avatar
What username should I use? I've had a quick look, but can't see a text file or anything I'd expect to contain a username.
Edit - google provided the answer: admin. Cheers Grant - EPC works perfectly here.
Old 19th August 2006, 21:20
grant620 grant620 is offline
grant620 is on a distinguished road
Coolio.
Glad you guys are happy
Old 21st August 2006, 09:15
BIG_Fella's Avatar
Grant
Cheers for the download most usefull
Jerry
