31st December 2012, 17:30
look s better than factory. It looks like the sort of colour they would use on aircraft bits
1st January 2013, 14:26
All the prep. work you put in is really paying dividends now as that looks great.
Good luck for 2013, Paul.
5th January 2013, 22:05
Barely perceptible progress
For my own sanity, here is record of further progress (just). Anti-roll bar fitted quickly this morning.
I am very aware that this thread is not yet a Sammio/Ribble build. It is just some bloke restoring a Herald in a shed in the woods. Please be patient. I'll get there eventually.
Those black bits may have to come off and become green at some point.
The shims will also get "touched" in soon.
6th January 2013, 13:30
Big Cheese
Loving the colour choice. Makes a nice change from 'chassis black'
6th January 2013, 19:34
loking forward to seeing rolling chassis, i remember seeing bellhousing, will that be the next surprise we see?
6th January 2013, 21:17
Rear suspension next. Then engine (nearly ready) and box. Then hubs and wheels......easy.
I would like to think that it will be back on its wheels in March, and then the big fun starts. I need to make a decision on the floor and get the chop saw and welder in action to make the frame.
7th January 2013, 08:25
Good to see you are making really inspiring progress. I am looking forward to seeing it sat on its wheels with the new adaptors attached and await your next adventure with Mr Mig on the framework.
7th January 2013, 20:47
Well that just looks fantastic. Very pro!
13th January 2013, 20:05
Two steps forward and one back
I reassembled the drive shafts this morning and discovered that there was a tiny bit of wear in one of the coupling yokes which is a pain. I have plenty of spare ones under the bench but I will need to clean them up and give them a spray of green.
Started rebuilding the rear spring and discovered that the teflon pads were larger in diameter than the housing in the spring (by 1.5mm). Milled them to the right size and they now fit snugly.
All back together now. As always, everything took longer than expected, but I did get a first coat of colour on the diff.
All very boring but I need to record it!
13th January 2013, 20:11
Lovely work, O. Did you rebuild diff? Only asking as i bought new gaskets and seals etc...
13th January 2013, 20:14
Thanks, Gary - all good fun and will be worth it in the end. No, I wasn't brave enough. I bought a fully reconditioned gearbox and a 3.89 diff from the legendary (within Triumph circles) Mike Papworth. He's a very pleasant and straightforward chap to deal with.
13th January 2013, 21:27
Top work mate, best chassis ive seen so far
14th January 2013, 08:43
Thanks, Mike, that's very kind, but I must confess that the camera is very forgiving. It looks better than it actually is.
There was a brief period when I was considering skimming the chassis with filler to take out the imperfections caused by 40 years of moisture and salt. Then I realised that if I did go down that route I should seek help, and psychiatrists are expensive. Hence I spent the would-be therapy money on a diff and gerbox.
Building a special.......I can handle it.
14th January 2013, 09:13
Morning O, I was going to ask how you got it so flat... but it sounds like the same as mine, plenty of pitting. Looks a lot better than rust...
22nd January 2013, 19:27
Snow, snow and bloody snow
This white stuff is starting to get on my nerves. The lane to The Glade is a right mess so I have been reduced to planning and some retiail therapy. This arrived this morning in the shape of a new 1:1.9 remote servo from the MGB Hive. It won't get fitted for a while but it's still nice to have. And, it will probably turn green before too long.
Oh, and of course there has been more painting. May I introduce you to an upside down zero miles gearbox.......in Sea Green.
I'm desperate to get moving on the rear suspension.
22nd January 2013, 20:00
My servo came from the MGB Hive - they're only about twenty miles away from me - it was dead easy to fit and gives the brakes some real bite compared to the standard setup. It'll also fit under the Spyder bonnet without any modifications if you put it where the Herald heater was.
Gearbox looks like you could eat your dinner off it, so long as you like greens.
24th January 2013, 19:35
Daft question time...
Is that as far as the gear box drainage bolt goes in normally?
I noticed my own sticking out about that distance & didn't want to force it in case it was cross threaded.
It is one of the many things on my to do list.
25th January 2013, 06:53
Morning Paul,
That is how the gearbox arrived, and the drain plug is in tight. Although it looks vulnerable, the bell housing extends much lower once fitted. All the little clutch actuator parts arrived this week so I may be able to assemble soon.......ah, the famous vague word......"soon".
26th January 2013, 10:50
Aargh!
Going through a temporary phase of stomping around thinking that my ambition outstrips my abilities and that I don't have the right tools. Why? The effing rear bushes on the diff. Time for a deep breath , some lunch, and then to try again.
Bushes are now in the freezer and the diff is on the radiator. Desperate times, desperate measures.
26th January 2013, 12:01
I believe I used vaseline and a 'G' clamp to get them in. Not easy though...
