Old 29th January 2008, 16:12
MartinClan's Avatar
Default Tank to filler cap pipe
The small length of tube that Marlin supplied was way too short so I purchased some from Europa. The problem is that although it is rubber the walls are very thick and it has very little flexibility (More suited to fueling Jumbo Jets..).
Can anyone suggest another source?
Old 29th January 2008, 17:58
Patrick's Avatar
Patrick Patrick is offline
I will have got mine from either:
http://www.nfauto.co.uk/
http://www.burtonpower.com/
http://www.merlinmotorsport.com/
http://www.rallydesign.co.uk/
I don't remember exactly where!
GreatOldOne's Avatar
Have you tried CBS?
FLEXIBLE FUEL FILL HOSE
Corrugated flexible hose with wire reinforcement for connecting your fuel filler to your fuel tank. Easily cut with knife & wire cutters. Resistant to leaded, unleaded petrol & diesel. 50mm ID Supplied boxed in a 3ft length PRICE £34.00
1' 6" length £19.00 + P&P
http://www.nfauto.co.uk/gates.htm
Old 29th January 2008, 19:09
MartinClan's Avatar
Cheers lads
It seems I went to the one place everyone else didn't - doh
Old 29th January 2008, 21:21
I got some of that stuff.
Mine is pretty solid and not flexible at all.
I found this quite handy when taking the rear tub on and off because it pushes itself over the fuel tank spout providing you get it in the right place. You can't put it on or take it off without removing the rear tub but once installed I don't think it needs to flex much?
of course it does mean you have to take the rear tub off to fit. Oh joy!
Old 30th January 2008, 07:41
MartinClan's Avatar
Thanks for the tip. I will wait to but some more till I have tried it. The tub has to come off again anyway 'cause I haven't made the boot floor yet. Next job after completing the bonnets which hopefully should be done this weekend!
