27th June 2013, 08:07
That was really good, that car really did look like it came from the 50's. I like seeing all the switchgear, and the aluminium panels... And the exhaust!!! Lots of ideas.
27th June 2013, 18:49
The side exit exhaust is the same as the original Lancia D24, and doesn't the 2CV motor sound great with no baffles! Awesome.
16th July 2013, 05:55
16th July 2013, 05:56
16th July 2013, 05:57
16th July 2013, 09:12
Lots going on! Hoping to get started on fitting my frame next weekend, one point is this a Sammio or a Ribble? BTW love the hole punch :-)
16th July 2013, 10:01
Thanks viatron !
It's a SAMMIO CHEVAUX indeed, maybe number 2 or 3.
RIBBLE is the new name of the company since january 2013.
16th July 2013, 17:53
Great work , looks very smart
16th July 2013, 20:04
Looking good - will it look a little like this one (at Stoneleigh this year) ?
I thought the exhaust exiting in front of the rear wheel was well executed.
18th July 2013, 05:46
18th July 2013, 07:29
One sheet of plywood, 2440x1220x9mm (shuttering ply is fine), is enough to line the inside of the cockpit. I used glass fibre to finish off the curved rear corners, but the designer cut triangular wooden fillets and bonded them in.
http://www.sammio.co.uk/Gettingstarted.aspx
Looking very nice now by the way, you'll have a car to be proud of in no time.
18th July 2013, 11:31
Thanks Mr T for your response.
In fact I need also wood to buit my luggage's compartment so I've bought one sheet of plywood but in 3100*1530*12mm.
18th July 2013, 13:08
Would aluminium sheet not be lighter to use, would help to keep the weight low and would stiffen your frame if rivuted on. Great work so far by the way
18th July 2013, 15:53
Aluminium has a lot of advantages when lining the cabin but is very expensive and i would imagin takes a lot longer to do, so i can understand why most opt for using wood.
My tub is aluminium and bonded/riveted which definitely gives the car a solid feel.
29th July 2013, 05:51
Others pictures !
It's not very easy to cut all the parts in wood at the good size but with a litle time its 'done :
Back sides :
And with the two side panels :
Back view :
a clean garage isn't it ?
This week, I will paint the frame.
1st August 2013, 05:59
1st August 2013, 06:39
Looking good Zeb !
Have you thought about fitting the more powerful 1.2 boxer out of a gs clubman
citreon. Would be a nice power plant for this low weight body.
Also what car do the lights come from, they are a nice scale for the car.
Keep up the good work .
1st August 2013, 07:20
Thanks Mikmiglia.
In fact I have hesitated a long time between the 2cv motor and the GS Motor (GS motor is the same than the AMI SUPER motor) but I wanted to built the car the much closer to registration papers of the car. So I 've keep the original 2cv motor.
I don't want to race with the car, only for pleasure and I like to take the time.
My lights come from CITROEN Ami6 or CITROEN DS estate.
5th August 2013, 06:12
Sebastien - Your build is coming together very nicely.
Bon chance, Paul.
28th August 2013, 09:43
good news :
All the wood panels are done and the body is fixed at the frame. I've to work on the bonnet now, not very easy to do !
I've done a lot of pictures during my holidays, I'will put them as soon as possible !
